Laptop does not turn on when it's unplugged
Hi, my laptop won't turn on when it's unplugged. The problem should be in the battery, can I fix it myself or should I go to a place?
How can I fix it myself?
좋은 질문 입니까?
좋은 질문 입니까?
Hi Ariadna,
Assuming you've checked that your charger is indeed working, then yes, the battery is the next logical part to suspect in a situation like yours.
The good news is that replacing the battery on your laptop is actually pretty easy compared to some. I don't have any iFixit-style step-by-step guides for you, but there's a YouTube video that shows the process pretty plainly and will easily get you through the process. If you can wield a screwdriver with any degree of confidence, you can replace the battery yourself. Here's the video.
ASUS e410 Battery Replacement guide, STEP by STEP - YouTube
You can search around for a replacement battery; they look to be available on all the usual sites like Amazon, eBay and AliExpress; pick one that works for you based on shipping times vs. cost; Amazon is usually the quickest but not necessarily the best price, AliExpress tends to be the cheapest but has the longest delivery times, and eBay is normally somewhere in between. Here's one of the first ones that came up when I did a search.
해당 답변은 도움이 되었습니까?
If your laptop won't turn on when it's unplugged, it is possible that the battery is the problem. Before attempting to fix it yourself, you should first try some troubleshooting steps to see if the problem can be resolved without having to open up the laptop or replace any parts.
Here are some steps to try:
Check that the battery is properly seated in the laptop. Sometimes the battery can become loose and this can prevent the laptop from turning on.
Try charging the battery for several hours and then see if the laptop turns on when it is unplugged. If the battery is completely dead, it may need some time to charge up before it will work.
If the battery is old or has been used extensively, it may need to be replaced. Most laptop batteries are designed to last for a certain number of charge cycles, and then they need to be replaced. Look up your laptop's model number to find the appropriate replacement battery.
해당 답변은 도움이 되었습니까?
24 시간 전: 1
7일 전: 20
30일 전: 94
전체 시간: 483
댓글 2개
Buy a new battery
[deleted] 의
Devon 의
