주요 콘텐츠로 건너뛰기
Released in May 2020, the 13" MacBook Pro features quad-core Intel 8th generation Core i5 and i7 processors, and Intel Iris Plus 645 integrated graphics. (Model A2289/EMC3456 with two Thunderbolt 3 ports)
66 질문 전체 보기
My device won’t charge
This time lasts year my device stopped being able to charge. I paid apple $600 to fix the problem. A year has passed and the problem has happened again. I plug in the device and it won’t charge. I was hoping to have this repaired for cheaper than $600 seeing as I’ll have to do it every year in perpetuity.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 2개
have you tried different cables, different power adapters? does the power adapter and cable work with your other devices?
is it possible there's dust etc inside the port?
it's possible that all they did before was clean the port out with compressed air in a can or perhaps after disconnecting the battery to eliminate the risk of shorts may have used IPA to clean out the port carefully with something to probe it, if that is the cause then probably wanna invest in some plugs for the charging port, I have silicone ones for my devices and it's great for keeping dust and any accidental splashes from getting in the ports.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
What did Apple tell you they replaced? As that might offer a clue on what has happened again.
As this model only offers one set of ports it’s not uncommon for the ports to breakdown from use MacBook Pro (A1989, A1990, A2141, A2159, A2251, A2289, A2338 Mid 2018-2022) USB-C Board to replace it you need to remove the logic board. We don’t have a guide, but we do have a similar systems teardown MacBook Pro 13" Two Thunderbolt Ports 2019 분해도.
But to be sure I would use a USB-C power meter to see if power is even getting through.
MacBook Pro (A1989, A1990, A2141, A2159, A2251, A2289, A2338 Mid 2018-2022) USB-C Board 이미지
상품
$14.99
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Robert Givens 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 5
전체 시간: 26
