주요 콘텐츠로 건너뛰기
Asus ROG 15'' ryzen-powered laptop released early 2021.
10 질문 전체 보기
I've tried adding a RAM upgrade to the single slot, and it never works
I've tried upgrading the 8GB single slot to 16GB single slot, and it never works and the computer keeps bricking - I know there is 8GB soldered on, but I've read you can upgrade the single slot, but it's not working at all.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
Interesting. I would check the manual or online to make sure that the speed/capacity of the ram is correct for the slot and mobo inside of the laptop. In the past, I have had similar problems with other computers because I went above the maximum supported ram for the computer.
If that does not work/the ram is the correct spec, I would try a different stick of ram and see if that works. Your ram stick may be bad and that may be causing the computer not to boot.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Douglas Parrish 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 12
30일 전: 42
전체 시간: 193
