주요 콘텐츠로 건너뛰기
The 2009-2014 Ford F-150 was introduced for the 2009 model year as an update of the Ford full-size truck platform.
71 질문 전체 보기
Why is my F150 not getting enough power to move after replacing the ma
Diagnostics stated the manifold needed replacing. It is still not getting enough power to drive or move after a new manifold was installed.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개:
If there was an error code, post it. On the chance that you misunderstood the error as a manifold fault, is this the manifold absolute pressure (MAP) sensor error, P0105?
댓글 달기
답변 1개
A MANIFOLD????
There is an EXHAUST and an INTAKE manifold. They are purely mechanical. I have never seen a diagnosis of a bad manifold.
Therefore, replacing one wouldn't solve any problems unless it was physically broken.
So, your problem needs more diagnosis. A problem like that should set a code. Unless maybe your parking brake is set.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
James 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 15
