I replaced the battery in iPhone 3GS and still does not work?
I received an Iphone 3gs second hand and was using for about a month. I went to turn it on one morning and nothing would happen. I plugged in to charge and it became very warm to the touch. I thought it might be the battery so I bought a new battery from i fix it and installed using their step-by-step guides. After I had the battery installed and was putting the phone back together the phone became very warm again. I tried to turn on - nothing. I tried to charge - still nothing. Any ideas what is wrong with it?
좋은 질문 입니까?
댓글 3개
Extreme (or sudden) warmth from these phones, especially when not under heavy operational load, typically indicates a short somewhere. Can you try running the phone w/o the back on and see if you can identify where the heat is coming from.
Phillip Takahashi 의
pretty tricky to do that on an iphone..take a good look at how to get the battery out and you'll see what I mean. The back holds the battery to the motherboard via a single screw, the screen is secured in place by 2 screws through the bezel..it'd be a real juggling act. It'd make more sense to do this without the screen on... as all the components are on the top of the board.
pollytintop 의
Thanks for your responses. The heat just occurred for a short time when I connected the new battery. Now nothing will turn on or happen with the device. So I am not sure how I can identify where it is coming from if I can not get the phone to run.
jccincy 의
