Disk does not exit the drive
I have a Optical drive that works perfectly. Reads/Write data without problem. However, when I eject, I see the mechanism eject the disk however the disk seems to stuck before leaving the drive. After a few seconds, the disk goes back in and is read again.
I obviously don't want to go trough the whole disassemble process of the drive. Is there an easy way to see if there might be something blocking between the drive and the iMac body?
Thanks!
좋은 질문 입니까?
댓글 2개
Has the machine been taken apart? Does the disk insert smoothly or is it scraping when inserted?
mayer 의
No, the machine was not taken apart except by me, that I just removed the cover to see. The disk insert smoothly and is "grabbed" by the drive.
Thanks!
Steven 의
