주요 콘텐츠로 건너뛰기
A crossover SUV by Honda introduced in 2002 for the model year 2003. The first generation was produced until 2007 when the car received a redesign.
12 질문 전체 보기
Does this mean I have to change the relay?
I do not see a fuse for the horn on my 2003 Pilot. I see a relay. Does this mean I have to change the relay? The horn died on me with no warning. Thanks for your answers.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
@inviernos48
check fuse #11 in the under the hood fuse box. After that check to see if your relay works when you push the horn button. Here is all you ever wanted to know about the horn on your Pilot. It should help with the diagnostic and the repair. Pilot Horn
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
Thanks a bunch. I don't think the under the hood fuse box has numbers but the one on the driver's side in the cabin does so I'll check that.
@andrewwinte4546 just double check the fuses under the hood as well. They may not have numbers but definitely check them out.
댓글 달기
귀하의 답변을 추가하세요
Inviernos 48 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 37
