All-in-one 3210 has print error Oxc18a0401, what does it mean EXACTLY?
Have replaced ink cartridges with HP02XL and still will not print. Have followed HP's proceedures with no luck. Any ideas?
좋은 질문 입니까?
좋은 질문 입니까?
Chuck, have you tried this yet:
"Solution 1:
Press and hold the "*" key. Press the "#" key and release both keys. Display should say "Enter Special Key Combo"
Press and release in sequence the "1", "2" and "3" buttons. Display should say "Support" and display the FW rev (something like R0631R).
Press and release the right arrow button until the display says "System Configuration Menu".
Press and release the "OK" button. Display should say "Hardware failure status". If not there already, Arrow Key over to "Hardware failure status",
Press and release the "OK" button. Display should say "Hardware failure status: Clear. Press OK to clear".
Press and release the "OK" Button. Message changes to "Hardware failure status Cleared. Press Cancel to continue".
Press and release the "CANCEL" button as many times as necessary, until the "Welcome to Photosmart Express" screen appears, or, the "Ink System Failure" screen appears. Do not try to print at this stage.
Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer.
Turn the unit on. The printer may display message "Use Power button to shutdown the printer" followed by "Press OK to continue".
Press OK. The Printer will start the "One time ink initialization process". Allow this process to complete and do not interrupt.
Once the initialization process is complete, the printer will print out a Diagnostic Page." Great information with more solutions from here. Of course I almost forgot, Error 0xc18a0401 Ink System Failure. Check on here for more infoas well. Hope this helps, good luck.
해당 답변은 도움이 되었습니까?
I had my doubts, because previous attempts were null/void, but this worked GREAT!!! I will print this article so it will be handy for possible future printing errors. It did take a few minutes for the first screen came up on the printer, but after that it worked as expected.
Thank you Thank you
mm
I don't see the Start key or number key on mine. I must be missing something
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 3
30일 전: 7
전체 시간: 3,381
댓글 1개
my error is Oxc19a0020
steven.northover 의
