주요 콘텐츠로 건너뛰기
The Xiaomi Redmi Note 6 Pro is a mid-range smartphone by Xiaomi released October 2018. It has a 6.62" IPS LCD display, a 12 MP main camera, a 4000 mAh battery, a rear-mounted Fingerprint, and runs on a Snapdragon 636.
20 질문 전체 보기
Phone is dead . Can't switch on after battery Full charged. Note 6pro
After visiting service centre they said that motherboard issue.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개
Not open switch off after full charge
댓글 달기
답변 1개
가장 유용한 답변
Hi Vishal,
We can't second guess the service center with regard to their diagnosis since we don't have the phone in hand to test it so if you disagree with them the best thing to do would be to get a second opinion at a different shop.
However, assuming you take them at their word and believe them that the motherboard has a problem, you have a couple of options. First, you can try to locate a repair shop that has the expertise to repair the motherboard, which can be expensive and the cost of which could easily exceed the value of the phone.
Otherwise the only other course would be to replace the motherboard yourself. iFixit unfortunately doesn't have a guide showing you how to do that repair, but there's a Spanish site called Nadie Me Llama Gallina that does.
Manuales / Xiaomi Redmi Note 6 Pro / Motherboard
You should be able to find replacement motherboards on either eBay or AliExpress; they look like they're running anywhere from about $30 to $50 USD new, but may be cheaper used on eBay. Here's an example of one that looks like it would work for you.
For Xiaomi Hongmi Redmi Note 6 Pro Motherboard Unlocked Original 32GB 64GB ROM Mainboard Logic Board With Google APP Installed - AliExpress
Take lots of pictures as you do the repair and use those to create your first iFixit guide to help others who have the same problem. It's easy, fun and the community will thank you!
Create a new Guide - iFixit
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Vishal singh 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 2
전체 시간: 84
