주요 콘텐츠로 건너뛰기
4세대 iPhone의 CDMA 버전. 수리는 간단하지만 앞면 유리와 LCD를 하나의 유닛으로 교체해야 합니다. 16 또는 32GB / Model A1349 / CDMA 호환성.
295 질문 전체 보기
dropped iPhone 4 in water!
yesturday i dropped in iphone in water and immediately took it out..shook off the and out the water and put a vacuum to all the holes..that immediately cleared up the camera window and the phone would turn on....i suctioned out phone for 15 minutes and put in a tupperware container over night filled with rice. phone works fine....can make and hear calls,text,internet etc only problem is when i look at phone you can see it like 3d..certain parts on display are dark when i go to a white or black screen?? when its a colored web page i see it normal..what can i do or whats wrong?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
I would first read through our electronics water damage wiki. This will help prevent further damage to your phone. Use our guides to help you take the phone apart for cleaning and inspection. If the screen still looks odd after you've cleaned everything you may unfortunately have a damaged screen and will need to replace it. We carry the display assembly here, but hopefully cleaning things up the rest of the way will fix your issue! Good luck.
해당 답변은 도움이 되었습니까?
점수 3
댓글 달기
귀하의 답변을 추가하세요
raquel 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 1,540
