주요 콘텐츠로 건너뛰기
Sleek Ultrabook™ with optical drive
7 질문 전체 보기
Why is my screen not coming on
I split a drink on my keyboard and the screen won't come on,but the power lights in the front are still on what can I do?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
@grizz51800 the last thing you want to do is to continue to try to start it etc. That can potentially make a bad situation worse. Remove the AC adapter and the battery. Then it is time to tear it down. you will need to remove the motherboard and all. Once it's removed, time to clean it with some 90% (or higher if you can get it) isopropyl alcohol. Follow this guide, and even so it was written for an Apple iPhone 3G, all the points are still pertinent to your computer as well. While you clean your board, check for any obvious damage, like burned or missing components etc. Best thing to do, would be to clean it with an ultrasonic cleaner, but if you do not have access to one, this will at least help.
Once all this is done, reassemble your computer and reevaluate. Until it is cleaned, everything will only be a guess. It is possible that you have a bad display connector (shorted out by the liquid), display cable or that the top case and/or keyboard may need replacement. To work on your computer, use something like this video no the exact same model but it should still help you working on yours.
Make sure that you take some good pictures of your motherboard. Both sides. Those may be necessary to identify your motherboard in case it'll require some board level repair. 기존 질문에 이미지 추가하기
While you work on your computer, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
iPhone 이미지
안내서
Repairing iPhone Liquid Damage
난이도:
어려움
1 - 2 hours
iFixit 이미지
안내서
기존 질문에 이미지 추가하기
난이도:
아주 쉬움
2 - 5 minutes
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Grizz 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 11
전체 시간: 49
