주요 콘텐츠로 건너뛰기
Repair and Disassembly guide for the 2020 ASUS G15 G512LI, A laptop produced by Asus for budget/light gaming.
21 질문 전체 보기
USB port low voltage (2V)
I was connecting arduino uno and esp32 via usb port , accidently usb port stop working , i tested the voltage output from usb port and it was 2v , is there a solution ?, can i replace usb port ?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Hi @wajihchaouch
With regards to the 2V, did you measure this on the input of the Arduino board when it was plugged in or on the USB port with nothing plugged into it?
If on the Arduino, measure what the voltage is on the USB port itself, without anything plugged into it. Alternatively plug in a USB mouse or keyboard and check if they work OK in the USB port or not
If there is only 2V on the USB port with nothing plugged into it, replacing the USB port won't solve the problem unless there's a high resistance connection in the port itself or from the port to the motherboard e.g. dry joint solder connection, causing the voltage drop.
The best option is to use the schematic and track the USB voltage supply from the USB port connector back to where it comes from on the motherboard to find out why it is only 2V and not 5V.
Unfortunately you have to buy the schematic but it is not that expensive.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
귀하의 답변을 추가하세요
Wajih chaouch 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 28
