주요 콘텐츠로 건너뛰기
Repair information for the 6th generation iPod nano. Released in September of 2010. Model Number: A1366.
20 질문 전체 보기
질문 마감됨
iPod Nano went through washing machine, help?
My iPod nano went through the washing machine. The next day, it wouldn't turn on but my computer would still recognize it. Now my computer no longer recognizes that it's attached, and it won't turn on. How can I fix it? Is it even worth it?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 3개
선택된 해법
Christina, the Nano is a bit of a PITA to work on. What you need to do, to get it working again, is to disassemble it using this guide. Clean it according to this guide. Replace the battery after cleaning it. The battery is a bit hard to find and a bit pricey but available here. Rice is a great first aid to pull some of the water out, but it will NOT prevent corrosion, nor will it displace water that accumulates under IC's or even within a case. As for if it is even worth it, depends on how handy you are and if there is any sentimental value attached to it. Hope this helps, good luck.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
put it for a day in a sealed pot filled with rice.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Hair Drier Will help loads
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
it did help it fixed it on itunes
댓글 달기
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 7
전체 시간: 5,330
