주요 콘텐츠로 건너뛰기
1.5 Core Solo, 1.66 또는 1.83 Core Duo, 또는 1.83 또는 2 GHz Core 2 Duo 프로세서
142 질문 전체 보기
질문 마감됨
Why doesn't my new harddrive show up in diskutil?
Hello,
I installed a new HD in my mini recently after the old one failed. But I can't see it in diskutil or the installer when I boot up from DVD (I tried all tiger, leopard and snow leopard disks).
First I thought I bought a broken harddrive or there is some problem with the mini.
I managed to boot xubuntu from a livecd on the very same mini. And there I can see the HDD fine; I can format it, read write ... whatever I want to do.
I can also connect the mini in target mode to my macbook and there I can access the HDD fine too.
So I installed snow leopard on the HDD via target mode. Now when I boot up I get a stop sign from the mini.
I'm puzzled - if there would be a hardware problem, why does the disk work in ubuntu?
Thanks!
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
Sounds like your new drive is to fast for your machine. Try using the jumpers to slow it down to 1.5. Do a web search for the name of your drive and jumpers to find the correct ones to jump.
해당 답변은 도움이 되었습니까?
점수 3
댓글 1개:
+ The jumper configuration for limiting the hard drive to 1.5GBs should be in a diagram on the hard drive's label. The jumper pins are located on the same side of the drive where the cable(s) plug into it.
댓글 달기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 984
