주요 콘텐츠로 건너뛰기
Apple의 메인스트림 2021년형 iPhone은 9월 24일에 출시되었으며 6.1인치 OLED 디스플레이, 듀얼 1200만 화소 카메라 시스템, 5가지 색상으로 제공됩니다. iPhone 12의 후속 제품입니다.
20 질문 전체 보기
My iPhone restarts automatically when it's idle.
My iPhone automatically reboots when it's idle, I've replaced all the gadgets and still seem to have this problem!
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Hi Xiang He,
That's a new one on me; I don't recall seeing this particular problem before. Can you elaborate on what you mean by "gadgets"? Do you mean you've deleted and reloaded all of the apps you've added to the phone?
First thing, let's see if the phone logged any information when it rebooted. Read Alisha's (@flannelist) wiki page on Kernel Panics to locate any panic logs that might be on your phone.
iPhone Kernel Panics - iFixit
If you find any, pull up the most recent one and add a screenshot or a copy/paste of the first page or so to your question and we'll see if we can figure out what's causing it.
Otherwise the best way to eliminate software problems is to restore the phone back to factory settings. Do a full backup then I'd suggest a DFU mode restore; that's the most complete one possible. Try the phone out and see if it's still rebooting after that.
If so, we'll have to try and figure out if it's a hardware issue. Otherwise restore your backup and double check to make sure it doesn't start rebooting again. If it does, there's something that's been loaded on your phone that's causing the problem. You may need to start deleting apps until you find the source of the issue.
Give these suggestions a try and let us know what you find.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Xiang He 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 1
전체 시간: 101
