주요 콘텐츠로 건너뛰기
2017년 9월 22일 출시. Model A1864, A1897. GSM 또는 CDMA / 64 또는 256 GB / 금색, 은색 및 스페이스 그레이.
660 질문 전체 보기
iPhone 8 Plus cellular issue
I have an iPhone 8 Plus and it has a few cracks on the screen and back glass which I planned on fixing but there’s an issue with the cellular and it is disabled in settings. Under modem firmware it is blank and status bar says no service instead of no sim. A restart brings the function back for awhile and modem firmware shows up. a restore didn’t permanently resolve the issue. I understand that the modem could have been damaged in the drop but would that cause it to intermittently work, Or would it not work at all if it was damaged? Is there anything else i should check? Everything else works on the phone.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 1개
가장 유용한 답변
If you are not getting a reading for modem firmware consistently, that's likely to be a board problem. The coming and going could result from the board's temperature fluctuations. Thermal expansion can cause things to touch under some conditions, or separate in others. It's also possible there's a mild bend in the board if the damage was severe enough.
Where are the cracks on the front and back glass?
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
the cracks were only hairline, they do go over the logic board. The device has crashed and I used a panic log analyzer which gave the possible issue of "i2c3 line"
댓글 달기
귀하의 답변을 추가하세요
CAB 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 25
