주요 콘텐츠로 건너뛰기
The Mazda Capella was commonly known in markets outside Japan as the Mazda 626. The Mazda 626's sixth-generation was built on the GF platform and released in 1997 for the 1998 model year.
55 질문 전체 보기
질문 마감됨
car over heat temp on traffic
when on traffic my car temp go up and when apply the gas it go down to normal temp
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
선택된 답변
I love my Mazda's.
Also check that the radiator fan is running. I had an old 323 once that about every year the fan would stop running, less a few taps with a hammer, and had to replace it. Same issue, heated up during a stop, and cooled down while driving simply because while moving air is flowing through the radiator to cool it.
If you can't find the issue, I wouldn't hesitate to take it to get it checked. The last thing you need is to get caught in a road jam and blow the head gasket.
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
On models with a radiator cap...if you let it sit idle after running it a bit, and add water, if it starts "spitting" the water out you probably have a bad thermostat.
댓글 달기
Check your belt on the water pump. It might be that your water pump needs to be replaced. Whenever you push on the accelerator the engine revs higher and the water pump turns faster......of course make sure that your coolant level is proper.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 555
