이 토론글을 스크롤하여 댓글을 달 적절한 위치를 찾으세요. 그런 다음 "이 게시글에 댓글 달기"를 클릭하여 댓글을 이동하세요.
댓글 1개:
@merolmeres that will depending on what make and model your phone is as well as the condition of the battery. Time to put an ammeter on your charging cord and see how many amps it draws (if any) The components you want to check are the battery, the charging port or charging board (depending on your make and model) as well as the flex cables etc.
oldturkey03 의
