주요 콘텐츠로 건너뛰기
The Meta Quest 3 mixed reality headset was released on October 10th, 2023 and is the direct successor to the Meta Quest 2 and in many ways the spiritual successor to the Meta Quest Pro.
7 질문 전체 보기
Disconnect built-in battery, What if you connect an external battery?
Disconnect the built-in battery,
If you connect an external battery,
Will it play normally?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 2개
선택된 답변
Hi That's not a smart idea, but if the external battery doesn't go under 30% and is the same ampere and volts it should be fine but I still advise you to connect the internal battery for the safety of the headset.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
@sungrimlee there is no reason why it wouldn't. All you need is the right voltage. I am sure that there are many out here that really would like to know why you would want to do that. Let us know what is on your mind.
해당 답변은 도움이 되었습니까?
점수 1
댓글 3개:
Built-in batteries are short-lived and use-time.
More importantly, removing the built-in battery can reduce the weight.
It's because I only want to use external batteries like Apple's Vision Pro.
@sungrimlee the execution on this could be a bit different. YOu may have to reuse or modify the battery controller and the connector. I am certain that the VR logic board requires the feedback from the battery. I wonder.....does the headset come on when you have an empty battery but connect the AC adapter? If so, I'd go through that port to supply power from an external battery. That would not require any mod on the inside of the headset/battery.
As I understand it, the built-in battery has to have some level of charge before an external power supply can be used. One can't just hook up a power supply to the charge point and start using it when the internal battery is dead.
댓글 달기
귀하의 답변을 추가하세요
Sungrim Lee 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 10
30일 전: 37
전체 시간: 345
