주요 콘텐츠로 건너뛰기
Nintendo Switch/닌텐도 스위치는 도킹 스테이션을 통해 TV에서 플레이하거나 이동 중에도 플레이할 수 있는 휴대용 게임 콘솔입니다. 2017년 3월 3일 출시되었습니다.
Switch Won't Turn On (Unpatched V1)
I'll get the unpatched part out of the way first. The serial starts with XAJ7003 which I believe is unpatched hardware that can be more easily modded. I don't intend to do this but it may be that the previous owner tried and bricked the console.
I bought a used "junk" switch from Japan and it failed test #1 - it doesn't turn on. No charging/battery icon and no signs of life. I did a bunch of tests listed below, and any parts or tools used are verified working from my store bought and still working fine Switch.
  1. Plug it in to charge for a few hours (official Switch charger to wall and USB to PC)
  2. Use a fully charged battery from a working Switch
  3. Hold the power button for 20s and then press again
  4. Open up and clean all ribbon cables and re-apply thermal paste
  5. Try to power on while docked in case the screen wasn't working
  6. Press the power button directly on the board/ribbon
  7. Test continuity on various things with multimeter (I don't really know what I'm doing here but everything I tested had continuity)
If I plug it into my computer it's listed in Device Manager as APX (!). Not sure if that means anything.
The internals were all very clean and beautiful other than a tiny bit of dust, which hopefully suggests nobody has opened it up to tinker before me.
I'm hoping someone could give me advice on what to try next.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 2개:
Me and u gang me and u😔
@jamaalkay check if its in rcm by downloading the software in the link i provided and connect the switch to the pc
댓글 달기
답변 1개
download tegrarcm from here https://github.com/eliboa/TegraRcmGUI/re..., connect the switch to the pc to see if it shows that its in rcm mode
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
No luck. Windows plays the device detected sound but TegraRcmGUI says "No RCM device detected".
However, after having it charge for a bit I did notice there's a warm spot on the top of the device between the volume buttons and the exhaust.
@fliggle_slaps if windows makes the connected sound then its possibly switched on. can you take the back casing and metal shield off
댓글 달기
답변을 추가하세요
Fliggle_Slaps 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 22
전체 시간: 184
