주요 콘텐츠로 건너뛰기
2016년 9월 16일 출시. Model 1660, 1778. GSM 또는 CDMA / 32, 128 또는 256 GB / 로즈 골드, 금색, 은색, 검정색, 칠흑색으로 제공됩니다.
Home button works but digitizer doesn't
When I separated the screen from the phone, I used a plastic spudger as usual, and when I reassemble the screen, the touch stopped working.
However the home button still responds.
I inspected the wire for the digitizer and home button and it doesn't seem damaged in anyway.
What could've gone wrong?
I passed that spudger from the bottom of the phone to the top.
Is it possible that I severed or damaged only one part of that wire?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
totally possible (tiny unfortunate tear, not easily seen)
more likely and easy (enough) solution:
re-seat the connectors
pita remove front assembly, remove cables, re-snap them back on (I like a good click, then a sort of tiny swirl push, not as much as getting fingerprinted!)
then, before you re-double sided tape that back, turn on and test (front assembly does jot have to be glued back to work); if all well, then stick it back together!
hopefully makes sense, and good luck
(and if you fail, it may be possible for the genius bar (apple store), to backup without working digitizer)
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Alex222 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 35
