주요 콘텐츠로 건너뛰기
Repair information for Asus G Series laptops.
13 질문 전체 보기
Why is my laptop flicking between plugged in and battery?
My laptop won't charge while turned on, it says plugged in when I attempt to charge it and then says battery and just alternates between the 2 while not charging. While off it charges fine, when I turn it on the red charging light turns off as it struggles to maintain charging it. I checked and my power supply whilst not the original that came with the laptop, the specs on the charger are suitable to charge it.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Hi @duck26742
What is the full model number of the laptop?
Create a battery report to check the status of the battery.
It may be that the battery is failing and this is why it behaves as it does.
When you have the report, compare the Design Capacity value versus the Full Charge Capacity value. For a good battery they should nearly be the same. You can work out as a percentage the condition of the battery now as to what it was when new, using the formula Full Charge Capacity value x 100 ÷ Design Capacity value
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Duck 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 26
