4세대 iPhone. 수리는 간단하지만 앞면 유리와 LCD를 하나의 유닛으로 교체해야 합니다. GSM / 8, 16 또는 32GB 용량 / Model A1332 / 검정 또는 흰색.
3270 질문 전체 보기
iTunes giving error 28
i have a iphone4 black 32 gb . it fully cracked from screen side. but i can receive calls but cannot see anything on the screen. it also recognize on the iTunes. i restored it on a 5.0.1 and activate it. i took out the logic board and put into the another phone . now it shows when ever i out the battery inside it goes to DFU . after battery fully drained putting on the wall charger it shows charging symbol and after few minutes it shows only apple logo on the screen and remained there. if we remove the charger from the phone it goes to DFU at the same time. i tried to restore with 5.0.1 but after preparing iPhone for retire it gives the error 28.
1. i changed the battery with other phone... but same.
2. change the dock connecter with other phone.. same .
3. put the logic board into the other working phone still same as before.
4. i took out the logic board for 4-5 days to fully discharged but same
5. i removed the shield from the board. i saw the one ic is automatically removed from the board . now what to to?
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글:
I can sell you a new iphone 3g 8gigs fully working bro!!! I want $260.00 and its all yours. go to ebay.com
의 답변
Are you saying that someone removed the GSM IC off your phone?
의 답변
no one removed the ic . it was removed automatically by falling on the floor from the roof. the screen and touch was shattered now i changed the screen portion with new. other things are intact.
의 답변
의견 추가하세요
맥북 배터리 수리 키트
기본 가격은 $69.99
Buy Now
맥북 배터리 수리 키트
기본 가격은 $69.99
Buy Now
1개의 답변
선택된 해법
SIMRAN, so the way I understand it, your GSM front end module is off. You can get it from here if you need a replacement. To replace it, I would possibly treat it like a reflow. also, have a look on here. I hope this helps, good luck.
해당 답변은 도움이 되었습니까?
점수 1
댓글:
thnx for the help. apple is replacing this phone on paid basis. they said they will provide a new iPhone against this on out of warranty charges. thnx
의 답변
의견 추가하세요
귀하의 답변을 추가하십시오
SIMRAN 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 6
전체 시간: 4,582
