MacBook Charges Battery, MagSafe Light works, but won't startup.
I have an original 1.83Ghz Core Duo that indicates that it is charging and fully charged, but will not boot. Attempts to reset the SMC have not solved the problem. Had been working almost perfectly for five years, and then one day, nothing.
I have tried different batteries and power adapters, and get the same result: It will not start up, but does indicate that it is charging or fully charged.
좋은 질문 입니까?
댓글 2개
Will not start up - is pretty vague description. Help us help you. Does it chime, flash, anything on screen? Have you had it open? Has it been dropped? What does attempts to reset the SMC mean? Did you reset the SMC or not? If you did, you mean nothing changed?
originalmachead 의
Thanks for your reply. When I press the power button, nothing happens. No chime, nothing. I has never been opened, never dropped. I followed Apple's instructions to reset the SMC by disconnecting the power supplies and holding down the power button. I replaced the battery, and reconnected the MagSafe. Still, nothing happened when I pressed the power button.
Apple2e 의
