주요 콘텐츠로 건너뛰기
Mac mini가 오랜 기다림 끝에 새로워졌습니다. 프로세서 옵션에는 3.6 GHz quad-core Intel Core i3, 3.0 GHz 6-core Intel Core i5 및 3.2GHz 6-core Intel Core i7 프로세서가 있습니다.
85 질문 전체 보기
The status indicator light is on once connected to power
My mac mini i7 cannot send video signal to monitor (black screen). I found the indicator light will immediately on (white) once I connected this Mac mini to power. Press the power button for 10 seconds, I can turn off the Mac min and the light also turned off. the light will be on if unplug and replug in .
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 2개
Have you tried anything specifically yet to fix this? This could be as simple as a bad cable. How are you connecting your Mac to the monitor?
I have two Mac mini, the other one is i5 I used the same hdmi cable. mini i5 is working well. I connected this working min i5 to the same power supply, the indicator light won't turn on until I press the power button.
댓글 달기
답변 1개
가장 유용한 답변
Given your symptoms I’m suspecting the I/O logic within the CM246 platform controller has failed, I’ve seen this before as the video wake line still functions which is what you are seeing.
Sadly, this system will need a new logic board.
해당 답변은 도움이 되었습니까?
점수 1
댓글 2개:
Thanks, Dan. Could you tell me the name of logic board and where I can find it ?
thanks,
@yuan24263 - This series has soldered storage, as such each version has a different P/N. Review this listing to find the one you either have now or if storage is a bit thin jump up to a larger version. 2018 Mac Mini Logic Boards
댓글 달기
귀하의 답변을 추가하세요
yuan 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 5
전체 시간: 31
