처리 속도가 빨라진 iPhone 3G 개선 버전. 이 기기의 수리는 3G와 유사하며 간단한 스크루드라이버, 비집는 도구가 필요합니다. 모델 A1303 / 16 또는 32GB 용량 / 검정 또는 흰색 플라스틱 뒷면.
1961 질문 전체 보기
No backlight after water damage
Hi, i have an iphone 3gs which has water damage. All seems to be working ok but the screen is dark. If i shine a torch i can see the images.
I have swapped the LCD but still dark. The 6r8 chip seems to look ok (not blackened)
There is some green corrosion around connector 1 and 3 and in a few places on the underside of the logic board.
I am awaiting some isopropyl alcohol 99% to be delivered. If i thoroughly clean the logic board and remove all corrosion, should all be well with the backlight?
Thank you
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
US$100 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
상점 둘러보기
1개의 답변
선택된 해법
Marc, possibly that things are going to be okay. Definitely treat the phone the same way as a water damaged phone. Clean it using this guide. It was written for a 3G but most certainly still applies. Re-evaluate after you clean the phone. If your backlight should still not work, test the 6R8 coil. Use this video or this one and see if it is time to change that coil. Now, if a coil replacement does not resolve your issue, there is still the possibility that it is your backlight IC 109B that is giving you the trouble. That will be harder to replace and will require special tools and techniques. I hope this helps to shed some light on your issue, good luck
해당 답변은 도움이 되었습니까?
점수 1
의견 추가하세요
귀하의 답변을 추가하십시오
Marc 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 841
