주요 콘텐츠로 건너뛰기
The Apple ImageWriter II is a dot-matrix printer released by Apple in 1985. It accepts both line feed and regular 8.5 by 11 inch paper.
Apple ImageWriter II won't print from Macintosh Plus
Hello! My Apple ImageWriter, even when connected to my Macintosh Plus through the correct selected ports, will not print. After I ran the self-demonstration, it proved that there is not a mechanical failure, and it will print. Whenever I select print in a document, it says it is printing, but nothing happens. Eventually, the pop-up goes away.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
You need to open the printer selector dialog box to reset the port. It’s likely the CMOS battery needs replacing as the setting got lost.
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
I have checked all settings, and they appear to be OK. I think it might the cable I was using that I bought. It might not have had the right pinout.
@wmf10 - this is a different cable than before?
댓글 달기
답변을 추가하세요
_nec6678 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 4
전체 시간: 133
