주요 콘텐츠로 건너뛰기
Apple의 메인스트림 2021년형 iPhone은 9월 24일에 출시되었으며 6.1인치 OLED 디스플레이, 듀얼 1200만 화소 카메라 시스템, 5가지 색상으로 제공됩니다. iPhone 12의 후속 제품입니다.
101 질문 전체 보기
Is there a problem with the motherboard?
I bought a defective iPhone. The phone is totally broken and I'm going to fix it if there's nothing wrong with the motherboard. It's iCloud locked and I could get the apple id credentials but I can't put them in because it doesn't connect to the internet or can't find the internet. I changed the wifi cable, it didn't help. the gps antenna is completely broken and I haven't tried to replace it yet. could it be that the phone starts working if I change the gps antenna? So is there something wrong with the motherboard?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
Can it find your provider network? Or can you use your providers data to connect? if your answers are no then try to connect whit your pc, but i think that you have defect in your motherboard (baseband chip broken). If you go to the Helo screen at the beginning and push on the litle circle whit the i in it, do the iphone shows it imei? If not then your baseband is broken.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Kokki 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 6
전체 시간: 40
