주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
G4 Quicksilver는 533MHz, 667MHz, 733MHz, 800MHz, 933MHz, 그리고 1.0GHz 속도로 출시되었습니다.
66 질문 전체 보기
질문 마감됨
Why won't my Power Mac shut down?
At first the computer would randomly start up by itself, not only when power was restored. Now the computer wont turn off when shut down is selected. Is there a simple fix?
이 질문에 답하세요 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
의견 추가하세요
SKIP THE UPGRADE
Save by fixing with an all-in-one kit.
Shop iPhone Fix Kits
SKIP THE UPGRADE
답변 5개
Tough one. What's the date on your computer? What happens when you power down using the start button? Hit command -option - escape (force quit) and tell me what's running. Do you have virus protection? You can always unplug it, but let's see if we can find a fix.
해당 답변은 도움이 되었습니까?
점수 1
의견 추가하세요
가장 유용한 답변
Could you boot from another external source and check if the problem persists when trying to shut down ?
해당 답변은 도움이 되었습니까?
점수 1
댓글:
Good suggestion, also check for any runaway processes using activity monitor.
Anitvirus scan or other update hanging?
의견 추가하세요
Try reseting the PMU (Power Management Unit) do this by turning the computer off (feel free to unplug it) then once it's off, hold the power button until the light flashes on and off rapidly, and the computer makes a tone.
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
If you have not changed the battery on the Motherboard, that might be it. IT can cause strange power up and down problems.
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
An "iPod shuffle 1GB", MB226C/A, sitting on its USB sync/charging base will initiate start-up if it is turned on and sufficiently charged.
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 3,587
