이 토론글을 스크롤하여 댓글을 달 적절한 위치를 찾으세요. 그런 다음 "이 게시글에 댓글 달기"를 클릭하여 댓글을 이동하세요.
댓글 2개
Please describe further what is wrong with it, is it one or all the keys, can you connect other keyboards to your laptop, and what happened to make it not work?
Can you describe what you were doing when this happened? Have you gotten it to work? have you tried taking it apart? You need to provide details for us so we can answer your question.
Check the keyboard cable for damages. It is more common than you think to accidentally damage a keyboard cable.
If you have other keyboards, try them. If you think it might be an OS problem, you can try the on screen keyboard available on windows. (If you use windows)
If it is a laptop and you are comfortable opening it, make sure that the keyboard ribbon cable is seated all the way. also, clean the cable.
If nothing works, then your keyboard is probably dead.
댓글 2개
Hampter 의
Hey man,
ArandomHitman 의
