Here you go:
Removal
1. Disconnect the battery ground cable.
2. Remove the windshield wiper arm/blade.
3. Remove the vent cowl cover.
4. Remove the windshield wiper motor.
5. Remove the pivot assembly mounting nuts, fixing screws.
6.Take out the windshield wiper linkage assembly from the opening of the cowl.
Installation
To install, follow the removal steps in the reverse order
Windshield Wiper Motor Removal
2. Disconnect the connector(2).
3. Remove 4 mounting bolts.
4. Remove the nut of the wiper motor shaft, and
disconnect the linkage.
5. Remove the windshield wiper motor(1).
CAUTION: To facilitate the removal of the nuts, be
sure to put out the tip portion of the linkage
sufficiently through the mounting hole of the motor
by sliding the wiper blade slowly.
Hope this helps, good luck.
