주요 콘텐츠로 건너뛰기
2020년 4월에 발표 및 출시된 2세대 iPhone SE의 수리 및 분해 정보입니다.
243 질문 전체 보기
iPhone Rear housing replacing issue
Hello,
I have a interesting issue/question. Maybe someone had same issue and can help me out.
Phone is iphone se 2020. Back glass is cracked and the metal frame part next to camera was so damaged that new housing was a must.
After replacing the housing (non original) the device boots up but does not charge via cable, only wireless charging works. i tried replace charging port with originals and also non original and the issue persists, but then i swapped the logicboard with screen into other iphone(iphone 8) housing(iphone 8 housing had all original 8 parts except logicboard, display and battery) and everything works flawless, after that i swapped it back into new chines housing and guess what the same issue is back again. Does not charge via cable. Looks somekind issue with ground i quess.
At this point im pretty sure, that the logicboard and also the original charging port are not damaged.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
Hi Carel, yeah my guess is either a grounding issue or a component that it doesn't like.
Best of luck, BetaTech Labs Repair AU
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
carel 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 11
전체 시간: 25
