주요 콘텐츠로 건너뛰기
Repair information for the Logitech K750 wireless solar keyboard. First available on Amazon in 2011. Model numbers: 920-002912 (Windows), 920-003472 (Mac).
13 질문 전체 보기
There's a key too sensible, can it be repaired?
Y got this keyboard second hand, after some time figured out that a key (B in this case) is too sensible, just holding softly the finger on it gets pressed, this does not happen in other keys, I understand that something is broken in the inside, do you think this can be repaired? I've heard that this can be the membrane, and is costly, does not worth it, any clues? Thanks in advance.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
Same here, on the Win key. I tore down the key assembly and the issue seems to be below the rubber dome, at the membrane switch (the part sensible to pressing that registers the keystrokes). As far as i can tell, this membrane switch works as follows:
  • being a conductive circuit layer, it is made of some thin sheet with printed circuits
  • that is positioned under the rubber dome
  • when you press a key, the rubber dome compresses, and the conductive part of the membrane contacts another layer below it, closing some circuit and registering a keystroke
Therefore there must be something, like a bit of dust between these contacts that causes the key to be super sensible. It probably requires a PCB-level tear down, or at least a good cleaning with compressed air.
On top of that, if my thinking is correct, the design of this keyboard is flawed being so susceptible to particles.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Javier Gomez 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 2
전체 시간: 34
