"No Batteries Available" displayed in upper corner of screen
My 2.4ghz macbook had the dreaded X intermittently appear in the battery icon in the upper right corner of the screen, and the dropdown would read "no batteries available." This would be the case even with a good battery in the computer. If unplugged, the computer would often run for a minute or two before abruptly shutting down. Gradually, this went from an occasional occurrence to the status quo.
좋은 질문 입니까?
댓글 1개
hi Bradford, if you wouldn't mind editing this a little then it would be even more helpful. Because you haven't supplied an answer in the "answers" part of the page, this question will be archived in 2 weeks as "unanswerable" and all your hard work will disappear! If you edit this at the 3rd paragraph and put the last 3 paragraphs as an answer then hey presto! this will be here forever and people can upvote if it's helpful. Don't forget to accept your answer as a solution too! Thanks for sharing, glad you solved the problem.
pollytintop 의
