주요 콘텐츠로 건너뛰기
The Xiaomi Redmi 9 is a low-budget smartphone by Xiaomi released June 2020. It has a 6.53" IPS LCD display, a 13 MP main camera, a rear-mounted fingerprint sensor, a 5020 mAh battery, and runs on a Mediatek Helio G80.
55 질문 전체 보기
My phone screen is coming out
Screen coming out of of the body without any damage
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
It's odd but not unheard of for the adhesive holding the screen onto the frame to fail; I'd suggest making sure the frame isn't bent and that's the reason the screen came off. If it's okay, then it should be relatively straight-forward to simply reglue the screen back onto the frame. You'll need some adhesive; something like B-7000 should work fine, or whatever you can get - for example the E-6000 glue iFixit sells would be suitable.
E6000 Adhesive Glue
Although you can probably reglue the screen without completely removing it from the phone, I'd suggest following this video and taking it all the way off so you can do a thorough job cleaning the old adhesive to ensure a good grip for the new glue.
Redmi 9 Lcd Replacement
Hopefully that's all you'll need to do to fix your loose screen! Let us know how it all turns out.
E6000 Adhesive Glue 이미지
상품
E6000 Adhesive Glue
$2.99
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Niranjan Kadam 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 10
