주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
The microphone on these seem to die easily.
I have two of these Eufy 2K Doorbells and both had their microphone failing after about a year of use. I unpaired one of them a now that one is useless since it can not pair anymore without the microphone. Anyone any suggestion if this can be repaired? Eufy can't deliver a spare microphone.
I think the microphone sits at the top, above the camera. Does somebody know for sure which part is the microphone?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 5
댓글 1개
I have had this problem with 3 previous EUFY doorbells. At almost a year on every one, the microphone dies.
댓글 달기
답변 2개
가장 유용한 답변
Thank you Mark for putting up the info pointing the way to the microphone.
Removing the rubber cover off didn't work for me but instead i replaced my microphone. If you like to tinker or know a tinkerer, you will need to replace the microphone that's soldered onto the board just as "MarkEwick" has said/displayed above. I replaced my microphone on my Eufy Doorbell with this following microphone:
(https://www.mouser.co.uk/ProductDetail/S...)
It now works like new again. It is surface mounted so tools needed ideally would be use of a hot air gun and some solder paste. (You probably could do it with just plain solder and a soldering iron but i took the more delicate approach). Took me roughly 20 minutes from start to finish/test.
I also came across another thread on here that almost shows you how to disassemble right down to where the microphone is and is useful.
(Eufy Video Doorbell 2k (Battery-Powered) Teardown - iFixit), after Step 6 you'll need to remove the remaining screws that hold the circuit board down / IR camera down and flip it to get to the microphone as pictured in Marks
Hope this helps anyone.
이 답변이 도움이 되었나요?
점수 3
댓글 1개:
Just stumbled across this as I have a T8213 and after an event in my front yard today, found that the audio wasn't present on the videos I downloaded and all settings were set properly. So being the nerd I am, I tore mine down to find the microphone as well. Used some 99% IPA and cleaned around the hole and rubber seal really well, and including the hole on the microphone itself as well.
Put it all back together and same result. Normal distance away the audio cannot be heard on my phone. However if you rub your finger over the mic audio inlet hole, or blow on the hole, you can hear the audio. So I knew it wasn't "dead" per se.
Wanted to look for a replacement on digikey or aliexpress and found this thread with the Mouser link. Copied the part number over to the US version site and they're in stock there as well! Nothing else is wrong and I've had this doorbell/cam for 4 years now so many thanks for helping me keep it alive! Huge help!!! Cheers!
댓글 달기
Interesting question as i have one opened up in front of me right now and despite stripping it down, im very unsure where the thing is..
이미지
these are images of possible mic with cover removing..
이미지
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
Ok so for those struggling with this issue, i took the little rubber cover off what i found out to be a surface mount condenser mic 6c03 1w22. I then put the 2 boards together with the push on pin connector but didnt screw anything up. I then went through the sync process and held the circuitry to the homebase... Successfully added!! It is the mics that are faulty here and it may well be that you would still have audio issues trying to hear outside, or maybe not.. 🙂 Ill keep it posted. Ive pressed on the pads of the mic incase they're loose, not going to try resoldering, only if i was replacing it and i only found similar mics online, not the exact one.
댓글 달기
답변을 추가하세요
Joris 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 4
지난 7일: 33
지난 30일: 106
전체 시간: 2,762
