주요 콘텐츠로 건너뛰기
The Xiaomi Redmi 9 is a low-budget smartphone by Xiaomi released June 2020. It has a 6.53" IPS LCD display, a 13 MP main camera, a rear-mounted fingerprint sensor, a 5020 mAh battery, and runs on a Mediatek Helio G80.
59 질문 전체 보기
My phone is not turning on
this is only occur when my phone is already at 0% and it will shut down by itself, if i try to 'on' my phone, the redmi logo show up and then disappear. if i try to repeat and it will be the same. this is the same while charging. pls help ;-;
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
@johnrett this could be a battery issue as well as a charging board issue. For now, I would suggest that you start with the battery (do consider the charging board since you have the phone disassembled already) Also, check the ribbon cable from the charging board to the main board for any damage.
Since iFixit does not yet have specific guides for this, use the ones from here Those have been written in Spanish. Use a browser that will do the translating for you, if needed.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has a device with the same issues as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
John Rett 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 10
전체 시간: 24
