The Nissan Altima is a mid-size automobile manufactured by Nissan, and is arguably a continuation of the Nissan Bluebird line, which began in 1957.
107 질문 전체 보기
Hard to start, after running a while.
My wife has 2006 altima that she uses daily only about 10 to 12 miles a day. After the car runs for 15 to 20 minutes and sits for 15 to 30 minutes it is very hard to start. The gas has to be pumped and turn over the engin and car will finaly start. This is not normal. my question is could it be the fuel filter or more likely the pump or something else. The service engin light stays on also. The car has 60000 miles on it.
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
US$100.00 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
상점 둘러보기
Ever fixed something? That’s Genius.
Share your repair story with #ImAGenius
We Are All Geniuses
4개의 답변
선택된 해법
mrfoot51, any way you could get Autozone or any of the other places to run a diagnostic scan on it? It does sound like the fuel pump/ pressure not acting right.
해당 답변은 도움이 되었습니까?
점수 2
의견 추가하세요
The first step in diagnosing any computer controlled vehicle is to check the computer's memory for a diagnostic trouble code. The check engine light being on is an indication that there is a DTC stored.
The symptom of hard starting after sitting for a short time could be a fuel system related component. If you have a leaky fuel injector, that would cause re-start problems.
해당 답변은 도움이 되었습니까?
점수 2
의견 추가하세요
camshaft and crankshaft position sensors just had the same problem with my altima
해당 답변은 도움이 되었습니까?
점수 1
댓글:
I always feel like there something else but yeah this fixing the problem for a little bit.. I replaced my sensors already 4 times in 5 years.
의 답변
의견 추가하세요
ECT (engine coolant temp sensor)
the ECT responds to change in coolant temp. by measuring the the coolant temp, the ecu knows the average temperature of the engine .
the ECT sensor is needed to controll many functions such as fuel injection, ingnition timing,variable valve timing, transmisions shifting ect.
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
귀하의 답변을 추가하십시오
mrfoot51 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 18
지난 7일: 129
지난 30일: 603
전체 시간: 15,155
