주요 콘텐츠로 건너뛰기
Samsung Galaxy Nexus는 Google NEXUS 라인업 주력 상품 중 하나입니다. HD 슈퍼 AMOLED 스크린, 곡면 스크린 및 Android 버전 4.0 Ice Cream Sandwich를 지원합니다.
41 질문 전체 보기
Volume down, solder, or?
So my Nexus Galaxy Volume down button doesnt work. I have isolated it to the motherboard connection, its "disconnected" on one point of the motherboard where the volume up and down connections are. I would rather fix it myself than to send it off to Samsung and have them tinker with it for a month. Is the connection on the motherboard a soldered connection? Heres a photo to help see what Im talking about (http://guide-images.ifixit.net/igi/noJOb...) Its the top part of the picture with the orangeish flap with the 3 connection points. The topmost point isnt connected like the other 2. Thanks for any help provided, Regards!
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 5개
So my Nexus Galaxy Volume down button doesnt work too!!!!!
Also I just bought it 3 weeks ago!
My Volume Solder points on the Mainboard are brocken.
Now i need alternative solder points for de Volume ???
I have the same question. Is this a soldered connection?
I have ordered this flex cable: http://cgi.ebay.at/ws/eBayISAPI.dll?View...
So I can't change the volume keypad without re-soldering?
Phone: Galaxy Nexus
@neumpe, the flex you got looks right. Yes, you will have to solder.
댓글 달기
답변 3개
가장 유용한 답변
Yes, those are soldered connections. Be careful when you try to re-solder it, so as to not take of the solder pads. If you have not done this kind of work before, practice on an old logic board first. You can of course also look for a new flex cable, just in case your should have small tears in it. Not exactly sure which model your phone is....different numbers, different flex :-) Hope this helps, good luck.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
@neumpe did you get it to work? I also have to do this after I was fixing my usb port connector, I accidently ripped this cable. I am ok at soldering and I am concerned about soldering to a flex cable.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Samsung galaxy v lues
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Chris Freeman 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 4,364
