2011년 7월 21일에 출시되었습니다. Core i5 또는 Core i7 프로세서. Thunderbolt. 이 기기는 Mac mini Server 구성을 실행하는데도 사용됩니다.
202 질문 전체 보기
SSD install did not work (software)
I managed to install my Corsair Force III 120Gb SSD in my brand new Mac Mini using the ifixit kit. I then cloned the original HDD to the new SSD and booted from it. All I got was a kernel panic (related, most of the times, but not at every boot, to ACPI).
I removed the SSD and installed it on a Windows machine so to upgrade the firmware to 1.3.3.
I re-installed the SSD in the Mac (by now I can do the job in ~5 minutes) but still no luck. I could only boot in safe mode.
I would therefore advise not to install a Corsair Force Sata III in a Mac Mini because it does NOT work. Also, if it worked, it would suck anyway because I benchmarked it (using the original HDD to boot) and speed is pretty much the the same as the standard HDD.
Has anyone managed to install a Corsair in their Mac mini and if yes, what results did you get?
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
US$100 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
상점 둘러보기
3개의 답변
선택된 해법
This is a 6 GB transfer rate hard drive and your MacMini will only see a 3 GB or less I believe. Jumper the drive to slow it down for it to be seen. There should be four jumper pins and I would try the two to the outside first then try the two to the inside.
해당 답변은 도움이 되었습니까?
점수 2
의견 추가하세요
Thanks, now the SSD is inside the Mac mini (used as a secondary drive) and I can not check, but I've never seen any jumpers on it. Also the Mac mini is supposed to be Sata III compatible. Also Corsair says the Force III series is fully compatible with Macs. Big bunch of liars.
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
hmmmmm….
my research shows that all mac minis 2011 and later have 6GB SATA:
ref:
http://www.everymac.com/systems/apple/ma...
and SATA III is the spec for the 6GB interface:
http://www.maximumpc.com/article/feature...
So the incompatibility lies elsewhere. Perhaps the corsair SSD is configurable??
해당 답변은 도움이 되었습니까?
점수 0
댓글:
It likely needs to be formatted with the correct structure for OS-X: GPT (GUID Partition Table)
의 답변
의견 추가하세요
귀하의 답변을 추가하십시오
pl0634 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 668
