The system doesn't recognize or doesn't know when to hibernate
I just purchased a used MacBook Pro Mid 2015 with a brand new Apple Replacement battery installed and noticing some odd behavior with the SMC?
First the MacBook was shutting down within seconds after logging with the battery still at 100%, 90% and even 60% (running off battery). So I thought it was an SMC issue so I let the battery drain and calibrate 3 times, reset the SMC with a with and without the power cable plugged in.
I was able to login fine with a power cable plugged in but it seems the battery was not able to either supply a healthy amount of power to keep the MacBook on? Or maybe just too new?
The SMC reset seemed to help with calibrating the battery but it still just shutsdown before hibernating when the battery reaches a low point. I get a notification to plug in the power cable though which is good! So there's been a little progress in that sense where the Macbook only shuts down due to actual low battery instead of a fully charged one. Maybe I just need to keep using it so the battery and SMC can develop a more regular pattern reading?
I can't imagine this to be good for my laptop though? And I'm still not sure if the MacBook can stay powered on after the login screen without a power cable. I'm almost too afraid of trying again out of disappointment. : (
Attached is a reading of the battery after it is fully charged and plugged into the power cable. When running the terminal with the prompt log shows
--predicate 'eventMessage contains "Previous shutdown cause"' --last 24h I get the number 0 which means "0 Battery disconnected. Check power supply/battery on a laptop, or the power supply for a Mac without a battery. On a laptop, the Mac should hibernate before the battery becomes so discharged it is unable to shutdown correctly, therefore if you see this shutdown cause on a laptop it may indicate a hardware issue with the battery or with the battery controller for reading the charge. Try resetting the SMC by connecting the switched off computer to power, holding ⌃control+⌥option+⇧shift and pressing power." and also -60 if I let the battery get to 0% without plugging in the power cable
"-60 Battery fully drained. Mac should hibernate before the battery becomes so discharged it is unable to shutdown correctly, therefore if you see this shutdown cause on a laptop it may indicate a hardware issue with the battery or with the battery controller for reading the charge. Try resetting the SMC by connecting the switched off computer to power, holding ⌃control+⌥option+⇧shift and pressing power."
좋은 질문 입니까?
댓글 4개
@zeekom - Let’s get a snapshot of CoconutBattery so we have something to work with. You’ll fill a link for it in my Answer above. The free version is all we need but once you get it I’m sure you’ll end up using it!
Dan 의
@danj Hey Dan, thank you for getting back to me, I really appreciate it. I actually spent a solid couple days looking through the ifixit forum and reading your very helpful and insightful tips and advice. I want to attach a screenshot of CoconutBattery readings but Im not seeing an attachment button in the reply box here, only in the "add your answer" section. Can you please help me with that, I apologize for not knowing.
Tashi 의
@zeekom - You need to post an answer, better yet is make a fresh question with your details and the snap.
Dan 의
@danj Hi Dan, I have updated the post and attached a screenshot as you requested. Thank you
Tashi 의
