iMac g5 wont power up/
How do I know my power supply is working properly, befor buying a new one?
좋은 질문 입니까?
좋은 질문 입니까?
You could try opening your iMac so you can turn it on and see if the diagnostic leds light up.
http://support.apple.com/kb/HT2831
in particular:
Locate the large white arrow in the middle of the computer.
Above this arrow, you'll see four LEDs:
LED 1 indicates that trickle voltage from the power supply has been detected. This LED will be ON when the computer is turned off and your power supply is working correctly.
UPDATE:
If the 1st light is on that indicates that the power is flowing to the computer. So it could very well be a logic board failure. At this point i'm not sure trying to repair a logic board failure is worth it.
Sorry.
Make sure you pull the HD though if you want to recover your data.
해당 답변은 도움이 되었습니까?
Thank you for your kind response.
I did tried to open it, and the led1 light is on, none of the others, and tried to switch on through internal button- no response and tried reset and again internal button- no response.
according to the apple literature- it is logic board failure- do you agree with that?
Thank you again
Is the #1 light on when the computer is turned off?
Thank you, when I plugged the wire to a outlet, it is on and when I take out the wire it is off. My main problem is turning on the machine with the button from the behind.
Thank you again
arivu
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 1,237
댓글 1개
Look on the bottom of the stand to find your exact model.
mayer 의
