주요 콘텐츠로 건너뛰기
처리 속도가 빨라진 iPhone 3G 개선 버전. 이 기기의 수리는 3G와 유사하며 간단한 스크루드라이버, 비집는 도구가 필요합니다. 모델 A1303 / 16 또는 32GB 용량 / 검정 또는 흰색 플라스틱 뒷면.
1963 질문 전체 보기
질문 마감
No imei, bluetooth, wifi. :(
Today i bought a iPhone 3gs 16gb black. its never been opened before. i opened up to see any damage . i changed 3 batteries but still same . i changed this logic board to another new working phone but same. i never seen a problem like this before. many people faced a problem of no imei or bluetooth. while restoring getting an error. but here different problem
NO error during restoring .
Not showing searching on the left side of the top corner only showing iPhone over there.
While updating an iPad baseband phone does not allow to flash it . on the screen this process not coming it directly goes for restarting the phone .
해당 질문 답변하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글:
this phone properly restored to latest version.
의 답변
의견 추가하세요
안드로이드 수리 키트
A new screen or battery is one kit away.
지금 장보기
안드로이드 수리 키트
지금 장보기
2개의 답변
It looks like the symptoms of a bricked baseband, however:
Make sure that you have all the parts completely screwed to the casing. It uses the case screws for grounding, and if a component isn't grounded, it won't work. Check all of your connections, and look for any damage to the board. There's a chance that you also may have bought a foreign logic board, and updated it with the wrong firmware/baseband. That would brick the baseband. However, you might have just gotten unlucky, and recieved a defective logic board.
I'd also try restoring from DFU mode, just to be safe.
해당 답변은 도움이 되었습니까?
점수 0
댓글:
but this is a new problem . have you ever seen a problem like this . i also one white 3gs 16gb white and iphone4 16gb black that both is not properly restoring. it will give a error of -1 at last stage . why this iPhone fully restoring to its original settings. and it will always is in searching mode. but this phone will not going to searching at any cost there is always shown iPhone over there. only iPhone is written as the space of searching ...
의 답변
의견 추가하세요
I HAVE SAME PROBLEM I dont know hot to BACK UP or Restore it irestoret in last FINISH RESTORE i have ERORR MESSAGE -1 but i dont know how to back mu iphone 3gs like before so please if any body know the fix solution let contact me on koliqi@msn.com
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 2,368
