주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
The Xiaomi Redmi 9 Prime was officially released on August 4, 2020 The smartphone is equipped with sensors such as a fingerprint sensor (rear-mounted), accelerometer, proximity, and compass. The smartphone features an Infrared port, USB 2.0, Type-C 1.0 reversible connector, USB On-The-Go, and Bluetooth 5.0.
Why my phone is not charging
My phone is not charging
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 3개
가장 유용한 답변
@anmolsotang you are really not giving us a lot of information here. It is always nice to know if anything has happened to the phone and what you have tried and checked to fix this.
First check your charger. Make sure it has proper output. Then check your charging cable. Check to make sure connectors are not bend etc. After that, check the charging port. Clean it of any debris etc, use a few puffs of air to clean it out. If none of this works, get a USB ammeter and see if your phone draws any amperage from the charger. If it does not it is possible that this is a charging port issue or a bad battery.
To check the charging port, use a voltmeter and measure the voltage on your battery connector. Next plug your phone charger in. Now measure the voltage on your battery connector. That voltage will have to have increased. IF not then the issue is either the port or the charging circuit.
Also check the flex cables coming from the charging board to the main board. Check that for micro tears and corrosion and proper connection to the boards. I suggest that you start with a new battery if any of the above did not work. After that it's the charging board and flex cables.
Since iFixit does not yet have any specific guides for that use something like this video. Replacement batteries and charging boards are readily available at many online stores.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has a device with the same issues as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
이 답변이 도움이 되었나요?
점수 1
댓글 달기
I don't know why my phone is not charging
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Mere redmi 9A switch off hone ke badd charge nhi ho rha hai
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Anmol Sotang 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 26
지난 30일: 72
전체 시간: 766
