Won't turn on after HD upgrade
So I went to install an upgraded hard drive in my MBP yesterday. I've taken the case off before so I figured no big deal.
Well now my computer will not turn on at all. I put the old one back in and still won't work. It makes a faint clicking sound from under the keyboard. The computer worked perfectly fine before I did any of this. I tried resetting the SMC, nothing happened.
Help.
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
US$100.00 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
상점 둘러보기
Ever fixed something? That’s Genius.
Share your repair story with #ImAGenius
We Are All Geniuses
4개의 답변
선택된 해법
The most likely thing is that the keyboard insert needs reseating. Do you get any keyboard lights?
해당 답변은 도움이 되었습니까?
점수 3
댓글:
I would say the same. Probably forgot to connect your keyboard again. I did the same thing once..
의 답변
Agree +
의 답변
의견 추가하세요
I would try pulling the battery, see if that has an effect, and then reseat the RAM, and see if that has an effect. If that doesn't work, I'd let it sit overnight with AC disconnected and battery removed. Sometimes laptops will retain a "bad setting", and letting them fully discharge with no power source resets them. Couldn't hurt to do the standard resets again as well without the battery.
해당 답변은 도움이 되었습니까?
점수 1
의견 추가하세요
it happened to me yesterday.
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
If you're hearing a repetitive clicking, that's probably your hard drive, and it sounds like it's failing. That click is the hard drive trying to spin correctly and failing.
Does the computer do ANYTHING when it powers on?
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
귀하의 답변을 추가하십시오
jewcydrewcy 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 1,433
