주요 콘텐츠로 건너뛰기
The Dell OptiPlex 745 small form factor is a compact desktop computer that has been a work office favorite, and still sits at desks to this day.
Why is my CD drive not opening?
When I press the CD drive button it does not open what to do?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개
@rufiniqbal what have you checked? Do you have power to the optical drive (CD drive)?
댓글 달기
답변 2개
가장 유용한 답변
Hi @rufiniqbal
Check if the cd drive tray opens if you click on the eject setting for the drive in Win Explorer.
Go to Win Explorer (press the Win key + e key - both together) > This PC > right click on the CD drive icon > eject.
It it opens OK, then the eject button on the drive may be faulty.
If it doesn't open, then there may be a problem with the tray motor or the drive electronics and further testing would be required to find the problem.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
You can try to force restart the computer
if that does not work, if there is a small manual opening hole in the drive door you can put a sim ejector tool into that to manually open it.
Or just stick a jimmy tool and pry until you can pull it out with your fingers
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Rufin Iqbal 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 10
전체 시간: 121
