주요 콘텐츠로 건너뛰기
Released in May of 2019, the Xbox One S All Digital Edition (model number 1681) is a revision to the Original Xbox One S (released in 2016). This model of Xbox One S ships with no Blu-Ray Disc Drive (thus there is no disc slit at the front), exclusively providing downloadable and streamable entertainment.
Why do I have a green screen on start up?
When I start it up it's stuck on the green screen. I've tried holding pair then press power on waiting for second beep to release pair button but no beep. I've unplugged the power cord from the system and tried restarting. I contacted the controller to the system and tried that way. Nothing is working.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
Hi!
First boot in safe mode and see if that works!
Booting in safe mode: Power off or unplug it. Plug back in hold the eject and sync buttons while holding them hit the power button. Don't let go of the eject and sync till the second set of beeps.
From there do a factory reset! And see if it works.
If not, or if it is having issues with formatting/installing, then the HDD need to be replaced! Replacing this isn’t difficult, but you do need to know some things before you swap it. If this is the case, it’s recommended to upgrade to a SSD. Way faster, less power consumption and lighter.
Please let us know if a factory reset fixed it, if not, please let me know. Then I can sent you some guides and also how to prepare the new HDD. Good luck!
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Jeremy Smith 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 5
전체 시간: 70
