hard to turn the steering wheel
We have a Craftsman mower and now I am having a difficult time turning the steering wheel. How can I fix this?
좋은 질문 입니까?
좋은 질문 입니까?
Mary,
Please make sure your tires are properly inflated.
Then look along the steering shaft for a grease fitting, and grease the shaft. Check for any worn guides or bushings along the steering shaft.
Look at where the shaft connects to the front steering arms, and make sure there is nothing binding them from turning, such as packed in leaves, dirt or grass. Look for a grease fitting down there as well as the axle and where the steering arms connect to the wheels and tires.
Look at where the wheels attach to the steering arms and axles again and try to determine if there are steering bushings which may be worn out. Replace those if you have them. Sometimes there are grease fitting in this spot as well. In fact, anywhere you see a grease fitting, you should pump grease in it regularly, maybe monthly or maybe twice a year.
If there is a rack and pinion setup for the steering, lay a bead of grease down along the rack and work the steering wheel back and forth several times.
After that, as long as nothing is binding the steering, and it is properly lubed and inflated, and nothing is worn out, your steering should be back to normal.
Good Luck
해당 답변은 도움이 되었습니까?
It has no geese fitting and it only 2 Mo old
Hi I am having same problem with my Mountfield 827m it’s lik driving a truck with no power steering. Jackie up and it’s light as a feather but not when you put it on the grass.
Anyone got an answer?
24 시간 전: 13
7일 전: 118
30일 전: 362
전체 시간: 31,279
