주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
모델 A1312 / Mid 2011 / 2.7 & 3.1 GHz Core i5 or 3.4 GHz Core i7 Processor, ID iMac12,2
My iMac doesn't work anymore after I replaced the CPU and GPU
Chinese: #1 LED shǐzhōng liàngzhe. Dāng wǒ àn xià diànyuán shí, luójí bǎn shàng de#2 LED huì shǎnshuò bìng kuàisù xímiè. Fēngshàn yěshì rúcǐ. Zhuǎndòng tíngzhǐ, zhuǎndòng tíngzhǐ, liánxù xúnhuán.
Wǒ chángshì gēnghuàn yǐqián de CPU, dàn méiyǒu yòng.
Wǒ zhǎole liǎng jiā wéixiū diàn, dōu wúfǎ jiějué wǒ de wèntí.
Wǒ xiǎng zhīdào wèntí chū zài nǎlǐ zài zhōngwén wǎngzhàn shàng, zhège wèntí de dá'àn hěn shǎo.
Wǒ bìxū shǐyòng VPN cáinéng zhǎodào zhège lùntán.
Tài nánle...
English: #1 LED is always light. When I press power, the #2 LED on my logic board flashes and goes off quickly.
The same goes for fans.Turn-Stop,Turn-Stop,continuous loop. I tried replacing the previous CPU, but it's no use. I found two repair shops, they can't solve my problem.
I wanna know where is problem.
There are very few answers to this question on Chinese websites.
I had to use a VPN to find this forum.
It's SO difficult...
from google translate
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
가장 유용한 답변
@kbcxmrjzy4igfbq - Liu Xiaoshu
Xūyào xiǎoxīn, yīnwèi bìngfēi měi gè xìtǒng dōu kěyǐ shēngjí dào nín kěnéng xiǎng yào de bǎnběn. Apple xiànzhìle xìtǒng gùjiàn zài Intel xínghào shàng bǎoliú de CPU hé GPU wéi dàimǎ de nèiróng.
Yóuyú wǒmen bù zhīdào nín dí quèqiè xínghào yǐjí CPU de qíngkuàng, yīncǐ wúfǎ tígōng yǒuguān xūyào wéixiū de nèiróng de rènhé zhǐdǎo, yǐjí gāi xìtǒng kěyǐ zhīchí shénme zuòwéi tìhuàn CPU(rúguǒ zhè quèshí shì wèntí bìngqiě kěnéng hěn nán jìnrù) zhōngguó dàlù. Nǐ kěnéng xūyào chóngxīn ānzhuāng yuánlái de CPU hé GPU xīnpiàn cáinéng yǒngyǒu yīgè kěyǐ gōngzuò de xìtǒng.
Wǒmen cóng nín yuánlái de tiězi zhòng kàn dào de yīxiē xiànsuǒ tīng qǐlái quèshí xiàng shì luójí bǎn wèntí, yīnwèi xìtǒng zhèngzài tōngdiàn (liǎng gè zhěnduàn LED dōu liàng qǐ, bìngqiě nín shēngmíng fēngshàn zhèngzài yùnxíng). Zài méiyǒu liánjiē xiǎnshìqì de qíngkuàng xià, bìngfēi suǒyǒu zhěnduàn LED dūhuì liàng qǐ, yīncǐ, rúguǒ nín bù shǐyòng tèshū de diànlǎn yáncháng xiàn lái gùdìng xiǎnshìqì, huòzhě zài liánjiē xiǎnshìqì de wèizhì zǐxì guānchá zhěnduàn LED, zé zhè shì kěyǐ lǐjiě de, yīnwèi lādòng xiǎnshìqì kěnéng huì chǎnshēng wéixiǎn. Diànlǎn sǔnhuài diànlǎn huò luójí bǎn liánjiē qì.
Nín néng jiěshì yīxià nín chángshì xiūfù zhīqián fāshēng de qíngkuàng yǐjí nín dí quèqiè xínghào ma
English: One needs to be careful as not every system can be upgraded to what you might want. Apple limits what the systems firmware holds for the CPU and GPU micro code on the Intel models.
As we don’t know your exact model and what it had for a CPU to even offer any guidance on what needs repair as well as what this system can support as a replacement CPU if that is even the issue and might be difficult to get in main land China. You may need to re-install the original CPU and GPU chips to even have a working system.
The few clues we can see from your original post does sound like a logic board issue as the system is getting power (both the diagnostic LEDs are lightening up and you state the fan/s are running). Not all of the diagnostic LEDs will light without the display attached so that’s understandable if you don’t use the special cable extensions to hold the display or carefully spy the diagnostic LEDs from where you can withe the display attached which can be dangerous pulling on the cables damaging the cables or logic board connectors.
Can you explain what happened before you tried repairing as well as your exact model.
이 답변이 도움이 되었나요?
점수 1
댓글 4개:
Sure,my MAC is A1312 mid 2011,I change CPU from i5 2400 to i7 2600,and change GPU from 6970M to K3100m
Thanks for your reply :
@kbcxmrjzy4igfbq - Wǒ gēngzhèngle móxíng xìnxī yǐ fǎnyìng nín de xìtǒng.
Zhìyú huàn chū CPU, jiùshì běn xìtǒng zhīchí de zhèngquè CPU. Dàn GPU MXM bǎn de gēnghuàn xūyào chèxiāo. Suīrán Apple quèshí shǐyòngle MXM zhǔbǎn, dàn bǎn zài wéi dàimǎ shì zhēnduì Apple bǎnběn de zhǔbǎn dìngzhì de, jiù xiàng CPU wèntí yīyàng, nín xūyào jiānchí shǐyòng Apple wèi gāi xìliè tígōng de nèiróng. Nín de xuǎnzé jǐn xiànyú 256 MB huò 512 MB Radeon HD 6750M qítā iMac xìtǒng de 512 MB huò 1 GB Radeon HD 6770M zhǔbǎn. Suīrán yǒuxiē rén shèfǎ ràng dài'ěr zhǔbǎn zhèngcháng gōngzuò, dàn wǒ hái méiyǒu chángshìguò. Yíhàn de shì, zhèxiē GPU bǎn wǎngwǎng huì bèi shāohuǐ, yīn wéi rénmen jīngcháng jiāng xìtǒng tuī xiàng chāochū yùqí de fànwéi. Jīběn shàng, lěngquè xìtǒng zài dàliàng gōngzuò fùzǎi huò yóuxì xià huì chūxiàn gùzhàng. Wèi liǎo jiějué zhè yī wèntí, xūyào shǐyòng ruǎnjiàn lái fùgài SMCS lěngquè luójí, cóng'ér tígāo fēngshàn de sùdù yǐ gǎishàn lěngquè xiàoguǒ. Dàn zhè shì zài sǔnhài fāshēng zhīqián, ér bùshì zhīhòu.
I corrected the model info to reflect your system.
As for the swap out of the CPU that is the correct CPU this system supports. But the GPU MXM board swap out will need to be undone. While Apple did use MXM boards the onboard micro code is custom to Apple versions of the board and like the CPU issue you need to stick with what Apple offered for this series. Your options are limited to 256 MB or 512 MB Radeon HD 6750M or 512 MB or 1 GB Radeon HD 6770M boards from other iMac systems. While some have managed to get Dell boards to work I haven’t tried. Sadly these GPU boards tend to burnout as people often pushed the system beyond what was expected. Basically the cooling systems failed under extensive workloads or gaming. To combat that one needed to ramp up the fans to improve the cooling using software to override SMCs cooling logic. But that’s before the damage takes place, not afterwards.
Thanks for your advice,I’ll try
댓글 달기
Hi, you tried both the old CPU and GPU?
My guess something cooked on the Power supply unit or motherboard.
You probably need to find a repair shop or person competent at board repair/ diagnosis. You could try a different PSU although it could be a waste of money . Unless someone has better ideas 🤷‍♂️
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
yeah,I tried both the old CPU and GPU,and only old CPU ,and only new CPU, umh……
댓글 달기
답변을 추가하세요
刘小树 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 8
전체 시간: 113
