주요 콘텐츠로 건너뛰기
기기를 고치세요
수리할 권리
부품 & 도구
Apple의 현재 소비자용 랩톱 MacBook Air 수리 안내서.
3948 질문 전체 보기
curser is stuck in upper right corner
My Mac book Air pointer is stuck in the upper right corner and will not move.
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
Nintendo Switch 키트
게임으로 돌아가기 위한 빠른 해결책
Nintendo Switch 키트 쇼핑하기
Nintendo Switch 키트
게임으로 돌아가기 위한 빠른 해결책
답변 2개
선택된 해법
First things first: provide us with the last four letters of your serial code.
I also take your keyboard is working fine... or it isn't?
While we wait for more informations, try the following things:
  1. Reset your SMC, as told in the Apple Guide, and try again. Is your trackpad working? If not;
  2. check what happens if you connect an external mouse, an economic, "windows" spare is fine, I use a Microsoft older than dirt with my Macbook and it never complained. If your keyboard has issues too, try with an USB keyboard as well Is your laptop working fine with an external mouse? If it does
  3. Try creating a new user account, or better, reinstall OS X on an external disk, if you can, or backup your data and try a fresh install
If it keeps being stuck, you may have a broken trackpad.
해당 답변은 도움이 되었습니까?
점수 1
의견 추가하세요
  1. Turn off your mac.
  2. Press the shift key on the left and the power button simultaneously to switch on your mac in “safe mode".
  3. If it was a software error your cursor should work fine in safe mode.
  4. If the issue doesn't persist when your Mac is started in safe mode, try restarting without pressing any keys.
    • If the issue comes back, you might have incompatible login items.
    • If the issue doesn't come back, it was probably caused by a cache or directory issue with your startup disk, which safe mode fixed.
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
귀하의 답변을 추가하십시오
Mark Atkins 가/이 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 7
7일 전: 58
30일 전: 240
전체 시간: 4,010
